Yep... should have used gloves. But hindsight isn't helping right now... has anyone found an effective method of getting Liquid Nails off your hands? I've tried vegetable oil and soap and water... time to just go the acetone?
Thanks!
Hi @MattB,
Sticky situation. Please don't use acetone. The amount you'll require could be a safety risk. Selleys has advised you to contact their emergency response hotline on Ph: 1800220770. They'll be able to direct you with the most appropriate cleaning technique.I would stress that you should not attempt to remove the product without consulting the hotline, as this could cause damage.
