hi there I’m looking to fix this corner of my front entrance. What sort of adhesive should be using?
many thanks.
Harry
Hello @hawkeeble
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about fixing your rendered wall.
I suggest using Polyfilla 500g Exterior Brick and Render Masonry in combination with UNi-PRO 50mm Real Good Paint Scraper. The general steps will be to clean the surface first and remove any loose debris still stuck to the surface. You then apply the masonry patch and allow it to cure. Once fully cured you then paint it with the same wall colour.
Here is a handy step-by-step guide: How to repair a rendered wall by @Nailbag
