My question was going to be can I cook on a barbeque plate after busting the rust on it with Ranex Rustbuster?
Hi @Eljay,
I'll have to check with Bondall, the company that produces Ranex Rustbuster when they reopen tomorrow, but I suspect the answer would be no, as nothing in its Safety Data Sheet indicates that it is food safe.
Please bear with me, I will get back to you as soon as I have an answer.
Cheers Jacob . I look forward to hearing what they say.
I've spoken with Bondall's technical team, who have confirmed that it would not be safe to use in this application. It is not a food-safe product, and it should not be used on surfaces that would come into contact with food.
You would be much better off removing rust from a hotplate using a wire brush or a wire brush attachment for a drill or angle grinder, cleaning the surface with warm soapy water, allowing it to dry, then coating the surface with a cooking oil.
If you did this, please remember to wear a mask, gloves and eye protection while removing the rust.
Thanks for following that up with Bondall, Jacob
Eljay
I just thought I'd add that we sell most standard-sized hot plates in-store. Just take the measurements of the plate with you, and our helpful team can assist with a suitable replacement.
Depending on how far gone the plate is, it might be worth replacing.
