Hello,
I've hit a minor issue with a delivery. I have a package that's just a hair too wide to get through my 820mm front door (about 10cm shy). The door is 40mm thick, so the solution seems to be temporarily removing the door itself to get the item inside.
I'm looking for some seasoned advice on the best way to do this. How do you recommend I go about removing the door from its hinges and then reinstalling it so that it's perfectly aligned, level, and functions as it should? Are there any specific things I need to look out for to ensure it goes back on without any issues?
Your expertise would be greatly appreciated! Thanks for the help.
