Hello, I am considering using James Hardie 2700 x 1200 x 7.5mm on external veranda ceiling. Would this be suitable and how far apart would I need fixings to be to prevent sagging?
The area is 8000mm x 1850mm, I plan to fix 2 pine framing timbers (70x35 should do) along each 8 meter edge (there is already a fixing point through the middle) Will this be enough to properly support the Hardie panelling of will it need more? At the moment this would mean the fixing points are about 900 between? Cheers.
