light stains of circles only just realised that now have been living here for about four months and want to know how to get it out. It’s only in this one specific room which is the toilet. Is there a way to remove the stains
Hello @helpwithrepairs
I propose trying CLR 750ml Bathroom And Kitchen Cleaner. My best advice is to make sure to give the CLR enough time to activate so that it can thoroughly dissolve the stains on the tile surface. Another method you can try is to use Glitz 2L Cleaning Vinegar, use a 50/50 mix in a spray bottle give it a minimum of 15 minutes to sit on the tile before washing it with water and detergent.
I propose scrubbing the surface using a Mr Clean Tuffmates Tile Scrub Brush. Make sure to rinse the surface very well and wipe the tile surface with a clean cloth.
Which one do you think is the most effective to use
I suggest using the CLR 750ml Bathroom And Kitchen Cleaner first as it is specifically designed for bathroom and shower cleaning.
