How to remove calcium stain from concrete pavers?
Hello @jocelyne
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about removing calcium stains on pavers.
I propose looking at using CLR 750ml Ready To Use Calcium Lime Rust Remover in combination with an Oates Compact Deck Scrub Brush. If you have a pressure washer, I suggest using it to rinse the surface of the concrete paver. I suggest doing a quick test on one of the pavers to see its effect, if you are satisfied with its performance, you can then commit the entire area.
