I would like to build a timber stud frame against my garage wall so that I can conceal some pipes(using plywood) and later fix cupboards and floating shelves to it. Could you please advise me on the following:
Timber selection – What type and size of structural timber would you recommend for this project? I would prefer to use untreated timber since the frame will be inside the garage.
Fixings – What type of screws or bolts should I use to securely attach the timber frame directly to the brick wall?
Frame-to-wall spacing – My plan is to attach the frame flush to the wall without leaving a gap. Are there any disadvantages to this approach? Should I allow a small gap between the stud frame and the brickwork for ventilation or to prevent moisture issues?
Ventilation around electrical equipment – How much clearance should I leave around these components to allow for safe airflow and heat dissipation?
Attached are:
My Garage
Sample 1
Sample 2
