Hi all I have water dripping from the machine, the spillage seems to be from the hose connection not sure if it’s the hose issue or siphoning issue anyone got any advice?
Hi @humbleguy,
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
Could you clarify which hose connection is leaking? Is it one of the two inlet hoses (hot or cold) or the outlet/waste hose?
From your description, it sounds more likely to be a loose connection rather than a siphoning issue. The first step would be to check and tighten the hose clamps on the outlet/waste hose, as this can often resolve leaks in that area. It’s also worth checking for any blockage in the sink waste where the hose connects, as back pressure could cause water to leak at that connector.
If tightening doesn’t fix it, the next steps would be to replace the hose clamp or the hose itself if it’s worn or deteriorated.
If you can show us where the water is coming from, that would allow us to give more targeted advice.
