I have got a 300x600 acrylic shelf which is 10 mm in thickness. What is the best way to anchor this straight/plane shelf to a plaster wall?
It will probably hold about 3 - 4 kilos of weight. I can locate the studs and screw a bracket in - but I dont think I will be able to put a screw through acrylic sheet safely - as such I'd need a clamp/bracket that can be screwed into the stud but has a U shaped or a semi circle grip, which grips on the acrylic sheet. I was under the impression such brackets would be a dime a dozen as I have seen many a glass shelves in showers affixed this way - but I am surprised to not see to many of these options in bunnings website. Is this the only choice available? https://www.bunnings.com.au/flexi-storage-decorative-shelving-black-matte-rectangle-shelf-clip-2-pack_p0127428
Any other suggestions please?
