im fixing some flashing to a rendered hebel wall. what screws do I need?
Hi @az,
You might like to check out the Fixing to Hebel Guide, which offers a number of solutions for a variety of scenarios.
Assuming the flashing is just sitting over the Hebel and not really applying a vertical load that would be carried by the screws, then you could just screw it to the Hebel using these 14g x 50mm Galvanised Hex Head With Seal Type 17 Timber Screws.
