Hi everyone, I just found the rubber seal going to dishwasher aquastop leaks. what part should I get from Bunnings to replace it?
thanks in advance
Hello @eegoos
There are two types of rubber washer you can use, it all depends on the type that is currently installed in your dish washer's inlet hose. The first is the Kinetic 12mm and 19mm Nut and Tail Washers - 8 Pack. The second set is the FIX-A-TAP Washing Machine Filter Washer - 2 Pack, please look carefully which one your hose is using.
However, if you discover that the inlet hose is actually broken, I suggest using the BOSTON 2m Burst Alert Washing Machine Inlet Hose.
