Could you please suggest the best method/material to fill up the gaps as shown in the attached photos. Gap is between the door frame and kitchen cabinet, and another one is between the celling and cabinets. Thank you.
Hi @Bharat1,
This type of gap is best filled with a flexible caulk such as No More Gaps.
Start by giving the gaps a quick clean with some sugar soap wipes to remove any residues that could affect adhesion.
Once clean, apply your No More Gaps along the seam. Check out How To Apply Bathroom Sealant as the process is much the same.
After applying, you can run a damp finger along the No More Gaps to smooth it and remove any excess.
Once dry, it is paintable if you'd like to, but this is not 100% necessary if you don't want to.
