I have purchased a shower pan for the bathroom Reno's, "Wet Area Solutions 900 x 900mm Solid Surface shower base". The question I have is: the shower base at the edges is 22mm in height, working on a tile width of ~10mm and glue ~7-8mm it doesn't leave a lot of room when coming up against the shower base. In trying to keep a bit of fall to the centre drain would I need to add a 6mm packer under the pan to bring the level up, this will give me a bit of breathing space running the tiles down from the shower pan to the centre drain. I'll be using Sikaflex to stick it down but I'm guessing this will only give me another 2-3mm in height.
I know this is ment to be a lower profile shower pan but will it end up being to low?
Thoughts.
Thank you
Danny
