im about to start tiling my outdoor patio with 20mm porcelain crazy paving. I have cleaned the slab but where it has had a wet edge for most of the winter it is stained. I’ve used a pressure washer and had a go with a wire brush but still pretty stained. Will this be ok to prime and tile?
second part to this, because if the wet edge through winter I’ve added an agi drain all the way around the patio to aid drainage and I’m going to use planiseal MR as the primer before tiling as this was recommended as a good water barrier that can be applied to damp concrete.
thanks.
