Hi all,
Looking to buy the kaboodle 60cm laundry cabinet to utilise as a base cabinet and add a bench and trough on. My question though does it come with a kickboard or not?
Hello @titantwo
The Kaboodle 600mm White Base Cabinet only comes with a shelf, screw fixings and its post legs. The kickboard will need to be purchased separately, but you do have the option of using other materials such as the CUSTOMpine 1200 x 295 x 16mm Carcass Shelving E1L White Standard Particleboard and cutting it down to the size that you need. Please note that the finish will be in melamine white and will not have the same finish as the Kaboodle 300mm White Gloss Modern Cabinet Door.
Thanks Eric - is there a link anywhere to buy the kickboard? Thanks I want to avoid making my own 😅
My apologies, here is the link to the Kaboodle 2400mm White Gloss Kickboard. Please note that you will need to trim it down to 600mm, the kickboard does not come pre-cut. While you are at the store don't forget to grab a set of Flatpax Utility Kickboard Clip - 2 Pack. This will allow you to push fit the kickboard onto the legs of the cabinet.
Thanks Eric legend cheers !
