Wondering how to change the LED light in the centre.
Do i have to remove all 4 heater lamps and then remove the cover to reveal the clips that attaches the LED light with integrated fan? How do I remove the cover/face?
I can see on the bunnings website for the replacement light but the installation manual isn't much help. I will also double check if it's ducted or non-ducted.
If it's ducted do I require an electrician to change the lights out?
https://www.bunnings.com.au/hpm-210mm-white-non-ducted-ceiling-exhaust-fan-with-integrated-led-light_p0375629?srsltid=AfmBOoplg18F9PU4n2cHCUKSbUC2iGBEejCcqeDtzkuKiayAdR0stv9b
Update: I have worked out removing the cover. It appears to be a standard light bulb change, doesn't seem like it has an integrated fan like the one listed on the website?
Hi @j0wie,
I believe you have this HPM 3-in-1 4-Lamp Instant Heat Ducted Bathroom Heater, which I can't see on our website, so you might be looking at a different model. The installation instructions are there if you have any need for them at this point.
Did you manage to change the bulb without any issues?
It looks like a fairly standard changeover, but if you have any trouble, please let me know so I can assist further.
Hi Jacob,
Thanks you for reply.
I spoke to a team member in store and they mention they don't stock the exact same light bulb.
Instead was able to suggest an equivalent Philips LED light bulb with an E27 screw.
And it fits and works now. Thanks
