I need to choose which one of the following to use over the bitumen paint on the roof.
Bunnings AI
Help improve the Bunnings AI Share Feedback
Need help deciding if the Gripset Betta 1L Waterproofing Membrane Bitumen Rubber is right for your needs? Ask me anything.
Is it suitable for outdoor use?Can it be painted over?How long does it take to dry?
Yes, the Gripset Betta 1L Waterproofing Membrane Bitumen Rubber can be painted over. It is a versatile product that can be used as both a waterproofing membrane and a bitumen paint. If you are planning to use it as a paint, you should dilute it with water in a 1:1 ratio as per the instructions.
If you need guidance on the best type of paint to use over this membrane or advice on proper application, please let me know! Would you like more details on the painting process or have any other questions about this product?
Yes. What paint can be used
Could you please clarify what type of paint you're looking to use over the Gripset Betta Waterproofing Membrane Bitumen Rubber? Are you interested in exterior paint, interior paint, masonry paint, or another specific type? This will help me recommend the most suitable options for your project.
Roofing paimt
Here are some search results for roof paints, roof spray sealants, roof waterproofing coatings, and roof treatment concentrates you might like:
Selleys 310g Translucent Roof And Gutter Silicone Sealant$14.45
Fastfix Wet Shield 1kg One Coat Instant Waterproofing$41.92
Ametalin 1500mm x 30m SilverSark HD Reflective Roof and Wall Insulation$94.82
Selleys 315g Roof and Gutter Spray Sealant$24.50
30 Seconds 5L Roof Treatment Concentrate$55.49
View more
Can i use these on top of bitumen?
Some roof paints and coatings are suitable for application over bitumen-based membranes, but it's important to check product compatibility for best results and longevity.
Here’s what you should consider for the products listed above:
Selleys Roof and Gutter Silicone Sealant: Designed for sealing gaps and cracks on various roof materials (metal, tiled, concrete, etc.) and can be used over bitumen, but it is a sealant rather than a paint or coating. It may not provide an even, paint-like finish.
Fastfix Wet Shield One Coat Instant Waterproofing: Suitable for most common roofing surfaces, including bitumen. This is a reinforced waterproofing compound and can be used as a protective top coat.
Crommelin High UV Resistant Roof and Wall Waterproofing: Crommelin membranes are typically compatible with bitumen and can be applied over existing bitumen membranes (confirm with manufacturer guidelines for the specific surface prep required). Once cured, they can be overcoated with acrylic paints.
Dulux Weathershield Exterior Paint: Generally designed for direct application on masonry, concrete, and metal. If you wish to use it over bitumen, ensure the membrane is fully cured, and confirm with Dulux or test a sample area first as adhesion may vary.
Other products (spray sealants, cleaning treatments, insulating foils): These are not designed as top coats or paints for membranes and may not be compatible.
