Hello
We removed a raised brick garden bed, it was butted up against the external wall. Water retained in the soil was causing damp internally.
We are hoping to lay some basic pavers to fill the space and also guard against future water penetration.
The plan is to dig a little deeper and paint a bitumen product on the lower bricks, that will then be filled in and paved over.
One factor is a submerged water pipe, (seen on the right) running the length of the bed. It’s almost at ground level, we don’t want to damage it! Placing a paver over this would result in a small step up.
The remaining bricks on the left are tricky to remove as the pipe runs through the cement between the bricks, again I didn’t want to cause damage when removing the bricks…. But would like to lose them.
Any advice on products and methods greatly appreciated.
Thank you!
