Hello
The render on my house exterior has a spiky finish which makes cleaning difficult and traps dirt (first photo).
I'd like to re-paint the walls myself with a roller but don't want the same finish and would prefer a flat surface so it's easier to clean. Is this the correct roller to use?
https://www.bunnings.com.au/uni-pro-270mm-21mm-nap-masonry-roller-cover_p0411668
This would be my first attempt with an exterior wall so would like some pointers. I read the reviews for the above roller that says to rinse the roller first so there's no lint. I've already got a Monarch cutting in brush for the edges.
Would a standard Dulux weathershield acrylic low sheen paint be OK? I've read that Dulux Weathershield doesn't need a primer - would you agree with this as it would save me a fair bit.
I think my existing might be rockcote with a sandy texture (second photo) which I don't want. Can I just paint over without sanding? There are a few very small gaps where there is no render so I'd like to repair these first.
Would appreciate some advice. Thank you.
my exterior wall
Rockcote render
