Hi, I am building an outdoor shed and have found lots of great info here. So much I’m potentially over thinking it. The shed will be 4.2m x 3m with a set of barn / French doors on the 3m side as the only opening. As height is important (I can’t go higher than 2.5m off the ground including the base it will be on) my questions are:
1. What is the minimum in cm fall / pitch I can have to accomodate a colourbond tin roofing. I believe it’s 5 or 6 degrees they recommend as the minimum. Would 240cm on the tall end down to 220cm on the short end meet the requirement for Flat roof / Skillon.
2. If I decrease the spacing between the rafters can I decrease the rafter size. Again with height being tight the narrow rafter will help. Would I get away with a 90x35 spaced closer than a 140x35. The span will be max 3m.
3. I don’t have a nail gun - what screws do you recommend for building the frame. Do they go straight in at the end or angled at the sides like you would with a nail gun.
just for reference I found this photo in here and is closest example of what I am looking at however my opening will be on the narrower side.
many thanks.
