Hi There,
my water pressure from my garden tap is too low for my irrigation. I
I’m considering to purchase a water pressure booster pump to connect to my garden tap.
could you advise what type should I buy?
Hello @slezak
Thanks for sharing your question about your water pressure. I'm sorry, but you are not allowed to attach a pressure pump to your garden tap. You can only attach a pressure pump to a water tank. I propose investing in a water tank such as the Water Tank Slim Tanks Direct 3000l Beige or similar. The tank can be linked to your roof gutter drain or be topped up with your garden tap. Once the tank has reached full capacity you can then use your pressure pump to operate your irrigation set.
Can you please tell us about your irrigation set-up perhaps we can offer other suggestions? How big is your irrigation set and what type of sprinklers have you attached to the pipe work?
Hi @slezak,
I suspect you have a problem with your mains water pressure.
You can also check the water pressure coming out of your garden hose and compare that with the neighbors.
Contact your water supplier for a pressure test.
Cheers
