Hey,
We've lived here a year, and the showers hot tap doesnt stop turning. So it doesn't leak, you can turn it off, but needs some trial and error as the tap doesn't give a clear stop position
We put up with it until the cold tap started doing the same: making it much harder to control.
I've started taking it apart (starting by checking valves, washers, normal maintenance), but come to a second problem. After removing one nut near the base , the spindle didn't come out. Instead I can see a second nut: much smaller (about 15mm)
and with more faces so hard to grip with spanners, vice grips. Looks like I need a new tool, but haven't seen such a small tap spanner before.
Have I got a strange tap- as changed a few in the past and never seen either issue? Thinking I might want a spare on hand before going any further.
