So I've built this wall frame for my window box air conditioner that sits in my sliding door tracts but can be moved out whenever I want to lock up. I did this because my real estate wouldn't let me put a split system in and I can't stand how terrible portable air conditioners are.
The issue is I've used H3 and H4 treated wood as the backside of the unit is at risk of getting wet as it is on my balcony. The posts it sits on that are outside are pine fence posts CCA H4. The rest of the build is pine treated H3 with the exception of the plywood which I believe is untreated which makes up the wall face, which means some of the H3 pine is inside the house on the front of the unit.
I've read online the H3 shouldn't be used indoors as the treatment can be carcinogenic and is toxic for indoor air quality. Indoor air quality is very important to me (I have an air purifier in each room of the house).
Is this project salvagable? Is their anyway I can still safely use this by painting or varnishing the wood to seal in the treatment and prevent off-gassing? Quite worried about this.
Thanks in advance!
