I need a cabinet kitchen hinge but dont know which one to get.
Attached are pics of the cabinet and hinge if someone can please help
thanks
I cant be 100 percent sure but looks like a Hafele 165 full overlay clip on hinge You can get them at Bunnings for about $12 a pair I suggest that you take the original in as Bunnings has a range of this type of hinge. and get someone to help compare it. There are lots of brands and they are pretty standardised. The main difference is the angle they open over. JDE
Thanks JDE will try that then
Hi @raffi,
It's fantastic to see that @JDE has already jumped in with some advice. As they've said, the main difference is the angle that they open and where they sit in relation to the side wall of the cabinet.
I'm relatively confident that he is correct that this Hafele 165° Full Overlay Clip On Hinge would be a suitable replacement based on the fact that the hinge is opening past 90° in the fourth image and the door sits fully over the side wall of the cabinet.
It would still be worthwhile bringing it into the store to compare in person.
Thanks Jacob will let you know how I go
This did the job. thanks for that
All good thanks this did the job
