I am planning to use the Bastion self-levelling compound for concrete floors. I had to remove my old hybrid flooring boards as the floor was uneven. After removing the boards and checking the floor, I noticed that most of the area is well levelled, but some spots have gaps of 2mm to 6mm. The corridor had a 6mm dip, which is where the boards started showing signs of an uneven floor. Now, I am planning to use the Bastion self-levelling 20kg bag. I need to do three rooms (3.2 x 3.6) and a small hallway. I have most of the tools for mixing but was hoping to get some guidance on what other items I need for levelling. I see in many videos the use of a spiked roller, but is this really necessary? Given once the concrete is levelled, I am planning to reinstall floor which is the Easy Plank hybrid flooring boards, which are 7.5mm thick.
also should i cover any small gaps under the skirting board?
thanks
