Hi, I need to put up a small metal cabinet. Its probably 800mm x 800mm by 120mm deep.
Based on where it needs to go it is unlikely I will find a stud. I know that these tiles are on a cement sheet product. The back of the cabinet has 4 small slots to enable the cabinet to be lifted above. The kit comes with a template so you are clearly limited to drilling as per template
the screws and then slide down into place
