We have large sliding doors to external patio.
We have traced leaks back to both sides of sliding doors where we can see the builder has left gaping holes. There seems to be no flashing or waterproof barrier - just holes, which has rotted the timber and is leaking downstairs.
We have removed plasterboard and archs/skirting to find these holes.
Now, how do I make it water tight as have limited access.
Below to the right of the yellow handled screwdriver is the larger of the 2 holes - you can see daylight through it. There is a smaller hole where the screwdriver has gone through.
Hole is quite big 50-60mm high.
Outside there is an air gap at bottom of external wall cladding of similar height. Water is getting straight in.
Waterproofing is only on part of this section (from the left corner up to where screwdriver is).
