Water leaks out of hindged side of shower door big gab any solutions. Door needs to open inwards.
Gap left side of opening door
Hi @Desperate,
Assuming your glass is 10mm thick, which is pretty standard with frameless glass in showers, you should be able to attach a Sandleford 10 x 2200mm Shower Seal Strip to that edge of the glass. When closed, it will press against the tile, blocking the water from exiting the shower.
These shower seals usually stay on pretty well without any help, but you can always use a bit of clear silicone in the channel of the seal to help hold it on.
If you have thinner glass, there are also options for 6mm and 8mm thick glass if you need them.
I will look into it.
Thank you for quick response.
Cheers
