A foldable table created for a jigaw puzzle enthusiast built using Pine, felt, castor wheels and cabinet hardware.
The project
This fantastic, fold up, puzzle table was a very special request from a loved one. Complete with a tilt-able top, four sorting drawers, wheels for easy transport, and a removable, stackable top for easy storage, this puzzle table offers so much practicality! A little more on the complex side, this project offered some challenges but overall, is a very user friendly build.
Steps
Step 1
Using the 6mm MDF panel and 42x19mm dressed Pine, carefully frame the inside of the table to ensure four identical drawers can slide into each opening. I ensured each space could fit a 290x290mm drawer. To secure the frame to the base, I used interior wood glue and nails, with a little help from my nail gun.
Step 2
Using the same technique, build your drawers to match the size of each. Again, frame the outside of the drawer using the 42x19mm dressed Pine. Once complete, sand and test their compatibility with the table and make any adjustments as required. I finished off the drawers by adding some small disc magnets in the back of the drawers using an 8mm drill bit and superglue. I then added small metal clips on the rear of the drawer sections in the framed base, ensuring the drawers remained secure when moving the table.
Step 3
Sand and paint the interior framing and bottom of the drawers to ensure the table is completely sealed.
Step 4
Using the oscillating saw, carefully cut out sections in the 3mm MDF panel to allow to the additions of the tilting block and magnetic closers. I measured the position of the unused framing space to guide this. Once you have done a trial fit and are happy, glue and nail the top to the framed bottom. I also used a few 6g 20mm wood screws to ensure there was no additional movement in the MDF during painting. After securing the top, I patched any imperfections using the gloss fine finish filler and sanded to ensure it had a smooth finish.
Step 5
I then moved my attention to the tilting top section of the puzzle board. Using 6mm MDF and 12x12mm dressed Pine, I carefully framed the top using small nails and wood glue. Once dry, I completed a trial fit to place the hinges, using a Stanley knife to carefully cut out sections in the MDF to sink them. I then fitted the magnetic stay clips to the base and rear of the top to ensure it clicked into place nicely. Lastly, I cut out my tilt blocks to hold the top at a 40 degree angle to reduce back pain while puzzling. I cut one side of the block at 90 degrees, while cutting the other at two 45 degree sides to ensure the block sat snug against the back corner of the slot. Lastly, sand and paint each piece separately.
Step 6
I then moved my attention to the base. I used 70x35mm Pine to create the frame for the base, securing each joint with 10G 70mm timber screws. I then lined the top and base with 3mm MDF, glued and nailed down securely. Next I used filler to fill any imperfections, sanded the full frame and painted. Finishing the base with some white no gaps filler on the edges of the base. Finally, I used the left over MDF strips to frame the bottom of the table so that the top was able to drop onto the base easily and securely.
Step 7
With every piece dry, I turned my attention to the cabinetware installation. This included installing the hinges, magnetic clips and handles.
Step 8
To add to the practicality of the table, I used these great little 360 wheels on the bottom of the table base so that it could be easily moved and adjusted.
Step 9
I used this great self adhesive felt to line the top of the table, base, and the inside of the drawers. This also helps the puzzle pieces to remain stationary when tilting the top of removing the drawers.
Step 10
Now the table is all ready for some serious puzzling!
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your home
Bunnings Workshop member Mick0s built a Kids play table with chalkboard top including tub storage to organise craft materials and toys.
Community member Tara86 built a small portable kids table tennis table which can be set up at the perfect height and is easy to store away.
Get more inspiration from 10 ways to make a side table, a selection of Kids play tables, and 8 ways to make a coffee table.
[article footer]
