I'm wanting to attach a Dyson vacuum mount onto the inside of a cabinet. The backboard is basically as thin as cardboard and about 1-1.5cm gap distance from the plasterboard wall behind so doesn't seem like a very sturdy option. I think that means I need to attach to the right hand side wall. The actual cupboard frame is 13mm and then I think there is another 10-15mm gap to the wall that is covered with a cover panel at front. I'm not sure if I should just use chipboard screws (how long?) or if something like a spring toggle wall anchor is a better bet? Vacuum weighs 3.5kg and then presume a little more with the mounting too.
