So a phone got dropped off the sink cupboard to the floor and it's left a crack on the single tile it fell on.
Touching the tile doesn't feel like there's a crack on the surface but it's a dark line on a cream tile.
How do I go about fixing it?
Hello @emilys
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about fixing your cracked tile.
I propose washing the tile surface with water and detergent to remove the dust and oil that has settled into the crack. Once the tile is totally dry, I suggest using Loctite 3g Super Glue Liquid Control. Apply a fine bead over the fine crack of the tile and allow it to settle and dry. This will prevent the tile from deteriorating further for a certain amount of time. But through wear and tear the patch will eventually wear out and it will be necessary to repair the tile properly.
