Hello!
Can someone help me to figure out how to fill this gap to prevent the rain water from going inside ?
Thank you !
Hello @Karellu
Thank you for sharing your question about your doorway frame gap. I propose using Turbo 175ml Builders Bog Flexipack to fill the gap. My best advice is to make sure not to add too much activator so that you have time to mould and shape the plug at the bottom. Once you have the plug in the correct shape, make sure to give it time to fully cure. Once fully cured you can sand it down to shape it further then paint over it in the same colour as your door frame.
