I have 4 fence pillars made of rendered blueboard that are in various stages of disrepair. Photo shows worst of these. As far as I can see they are sitting on a concrete footing. The dimensions are 400x420x1050
I'm planning to try my hand at replacing them, starting with the one pictured. I have to go with a solution that gives an end result that matches the originals as one is on the boundary and shared with the neighbour (who also has 4).
My thinking is to construct an internal frame from 90x45 H4 timber and clad with blueboard. If possible I'd like to use a textured paint rather than a render beause I don't feel confident applying the render. I'm assuming that if i don't render then I can't really use a render bead on the corners, so I want to know if there are other ways of finishing the corners that would work? The internal frame would fully support each edge of blueboard, so could I get away with taping? Or should I do everything up to the rendering and then get someone to do the rendering for me?
Any thoughts would be appreciated.
