Hello
I want to dismantle & clean my Anko box fan but it has these triwing screws. Does Bunnings have a suitable screwdriver for these? Some people suggest a torx set online but I don't know what size to get. Thank you.
triwing
Hi @LorenClayton,
That's a bit of a tricky one as tri-wing bits are not all that common. In this Craftright 100 Piece Screwdriver Bit Set, there are a few bits that could suit. The other issue is that the bit itself needs to be placed in a holder, and the holder might be too wide to fit down into that recess.Regarding the torx question, they are a different style and won't fit the tri-wing screw.
Success! I just went in & asked. The guy suggested that I get this Stanley set because he said it had the triwing bit, which it did, but it was too big.
What worked was the one above it, triangle size 1. And the driver was just the right fit for the fan holes. These were easy to get out using this so it was a good buy & I'm sure will come in handy for other things. Thank you Mitchell!triwing screws outStanley set.
