Hello @erazor
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about cutting a hole in a solid surface benchtop.
In the interest of health and safety I suggest engaging the services of a professional. Generally speaking, you can cut the hole in the solid surface with the proper hole saw blade. But if done incorrectly there is a high chance that the cut will not be straight or that the solid surface will get damaged by heat. A benchtop professional will have the proper tools and technique to cut the hole safely and prevent it from getting damaged. Plus, should anything happen while cutting the benchtop it is covered under the professional's insurance.
