Hi everyone,
I've been lurking on here for a while getting ideas for building my shed. Decided to DIY due to the costs of the timber kit sheds.
I have an already poured concrete slab up against the boundary of my house and close off fence, the shed I'm looking to build is 3600mm x 3450mm (frame size). Height is 2700mm or so high side and 2400mm low side. With roof on it'll be just at 3m above ground at the high side. I realised that the slab I got poured is bigger than the floor space of the shed I can build as the slab was also to clean up the corner near my retaining wall. I've got a few questions that I hope I can get answered.
Waterproofing:
I've read this lots of posts like this: https://www.workshop.bunnings.com.au/t5/Garage-and-Shed/How-to-waterproof-shed/td-p/196408
as well as how to waterproof a shed floor. Do I follow the same principle here with Sikaflex 11FC and an unequal angle? How would I incorporate dampcourse under the bottom plates? I'm using H3 90x45 pine studs throughout the build.
I also have expansion cuts in the concrete which I didn't realise would create a water channel to get into the shed floor. Would I run extra Sikaflex down into that groove to try and prevent anything coming through?
Flooring:
I'm looking to lay laminate flooring inside as I have a heap of it left over from my house build. What would be an appropriate underlay that would protect the shed and floor from water damage?
Door frame:
Would I keep the bottom plate as shown in my sketchup or would I cut this out and fix a door jamb timbers to the concrete itself? And I'm looking to put a 920mm wide external door in, for a standard stud wall opening, am I looking at 2080mm x 955mm?
Guttering and Roofing:
I'm looking to put in Colorbond roof sheets (one of the more fancy profiles, not standard corrugated). Does guttering attach directly to my fascia boards at the low end of my roof?
Cladding:
Looking to use some sort of hardieboard cladding just to keep costs down. I assume timber cladding boards would be super expensive. Something with a bit of texture would be nice. Any recommendations?
General:
Does my overall stud wall design look sound? I think I'm supposed to have noggins between my last rafter and the top plate of the side walls?
This is my first time tackling a job of this size. I've built stud frames for a theatre room platform but nothing at this height.
I'm not going to use this shed for anything other than a storage shed. We want to keep it vermin proof as much as possible, what steps would I need to take to do this?
Thanks for your help, I've learnt a lot just reading through responses on this forum already! I've attached pics of the slab and the design below.
Dan
