Seeking ideas on a weed free and low maintenance landscaping for gap between concrete and fence here and how to DIY it. Thanks.
Hi @ELI5,
The idea is to create a clean foundation that prevents weeds, then use a small selection of hardy plants that hold their shape without constant attention. This approach gives you something visually striking but still practical for a narrow space.
A strip filled with succulents would work beautifully beside a Colorbond fence because they'll stay neat, handle heat well, and keep maintenance to a minimum.
Begin by laying weed mat along the length of the strip. It will act as the main barrier against unwanted growth and save you from ongoing work.
You can then cover it with a layer of decorative stones such as river pebbles, white quartz, or charcoal gravel. Stones give the whole area a finished look and provide excellent drainage, which succulents love. To plant, cut small crosses in the weed fabric and tuck each plant into the pocket, then pull the stones back around the base so everything looks seamless.
For plants, choose varieties that stay compact and cope well with reflected heat. Succulents, such as small aloe cultivars, sedum, and echeveria, are all excellent because they are tough and sculptural. A simple layout works best. Place a slightly taller focal succulent roughly every metre, then fill the gaps with lower spreading varieties. This creates a rhythm along the strip without overcrowding it, and the different leaf shapes add interest while still looking tidy.
Once planted, the care required is minimal. Water weekly for the first month, then reduce to occasional deep drinks during very hot periods. Succulents rarely need trimming, and the stones help keep everything clean and weed-free. Over time, you may top up the pebbles to keep the surface fresh, but otherwise, the space more or less looks after itself.
Let me know what you think.
How about how to cover the space under the fence to prevent the stones from rolling into neighbour's. picture
You could use some garden edging in a style of your choosing, then stake it in place against the fenceline.
Most options will have a garden edge stake that will match or at least work with that edging. Securely staking the garden edge will prevent bowing and will help to hold things in place long term.
You might like to check out How to choose garden edging for some guidance.
Alternatively, you could install a barrier using timber sleepers, fixing them in place with sleeper pegs.
Thanks. What can I use to level the ground before putting weedmat, the area is quite small for a shovel.
In a small space like that I would actually avoid trying to level it with soil. Soil can trap water and create pooling. I would instead level the ground with drainage gravel. Once you have your garden edging in place along the fence, you can simply pour the gravel in rather than trying to work a shovel in the tight space. Fill the area until the gravel sits roughly twenty-five millimetres below the height of the concrete slab. Give it a light tamp to compact it. You can then lay your weedmat directly over the drainage gravel and finish the surface with your decorative stones. This creates a stable, level and free-draining base that helps carry water away rather than letting it sit in that area.
"..you could install a barrier using timber sleepers, fixing them in place with sleeper pegs."
Please how will this work, do I screw the sleeper to the face of the bottom rail/post or will it be fit under the bottom rail? Thanks
The sleeper is usually placed along the bottom of the fence on the ground-facing side, with sleeper pegs driven into the soil behind it to hold it securely in place. It doesn't normally need to be screwed to the fence itself.
If you want the sleeper to sit underneath the bottom rail, you would need to dig a shallow trench so part of the sleeper can be buried and fit under the fence.
Another option is to attach a board directly to the fence posts or rails using screws. In this situation, treated pine plinth boards are often used instead of full-sized sleepers because they're lighter and easier to install.
Thanks, please do you have a video or pic of what this would look like
"..The sleeper is usually placed along the bottom of the fence on the ground-facing side, with sleeper pegs driven into the soil behind it to hold it securely in place. "
Hello @ELI5
I've placed a sample image below to give you an idea of how the sleeper is positioned and how the sleeper peg is used. Please note that I am using the 50mm Sleeper Peg Galvanised Steel as an example. There are a quite a number of sleeper pegs you can choose from.
Thanks, does the top of the peg directly sit under the bottom rail or is it in front of the bottom rail
There currently isn't enough room under the bottom rail to fit a sleeper or the pegs, so the sleepers would sit in front of the fence. The top of the peg would be above the bottom rail and in front of it.
