I’m planning to hang a 160g mobile from the ceiling. I considered using a 3M/Command hook, but I’m concerned the adhesive might lose its grip or peel off the paint. What’s the best way to hang it with minimal damage to the ceiling?
Hi @inno,
Although it is relatively lightweight, I would not be confident attaching a hook to the ceiling using an adhesive, as over time the weight will move around and pull on it and assuming that it may be hung over a baby, I wouldn't be comfortable with this, regardless of how lightweight it is.
The solution I would recommend is this Zenith 10 / 15kg White Small Ceiling Hook. They can be screwed into timber framing if it is available, or into plasterboard using the expansion anchor.
It would put a small hole in the ceiling, but it would be very easy to patch when needed, and I'd be happy to help if required.
Let me know what you think.
