Hi -
I need a suggestion on whether I should install a strip drain on the left side of the house, in the side alley. The slope is adequate for water flow, but the home inspector told me when I bought the house that rainwater can pond or flow toward the house wall and then flow out. So, later I asked the plumber to install a strip drain to direct the water to the stormwater system. Weep holes are also obvious and cleaned, and there is no moisture inside the house. I am only concerned about whether I should order a premium strip drain, which is an expensive solution, in case of windy rain. Even if the strip drain is installed, water or moisture may still enter the weep holes during windy or monsoon rains. Alternatively, I could use Sikaflex to seal the gap between the concrete and the wall, leaving the weep holes open before and after applying Sikaflex. Or I could do nothing and leave it as is, since there are no signs of moisture, mold, etc., and water flows toward the side gate. I know the slope isn't ideal, but it's acceptable. I used the water hose to see where the water flows. Attached are pictures and a video for reference. I really appreciate any help you can provide.
Does anyone share the experience and guidance on that?
