I'm planning to repaint this interior window sill and frame. As you can see in the attached picture, the old paint is peeling and flaking.
What is the recommended process for preparing this surface? Specifically, how should I address peeling paint, and what primer and finish paint should I use to ensure a durable result?
There's a small gap where the vertical window frame meets the horizontal sill (on the far right in the photo). What is the best product (like caulk or sealant) and technique to use to properly seal that gap before painting? Should I seal it before the painting?
- What is the safest, recommended way to remove the vertical blind slats (vanes) and the headrail/track from their mounting brackets without damaging them, so I can reinstall them?
Your expertise would be greatly appreciated! Thanks for the help.
