Hello and thanks for all the info you post. I am building a low level deck to be tiled on tile cement underlay instead of decking boards (30 cm above ground) which is 6 meters by 6 meters and I have tried to use the span table but just can get my head around it. I want to use the h3 treated pine 140x35 h3 for the bearers and 90x45 h3 treated pine for the joists and my posts will be 100x75 h4 ( is this size allowable for posts or do I need to go to 100x100).
I want it safe, but also want the most cost effective way with timber you supply. So my question is as follows
1: how far apart do my post need to span with posts listed above
2: how far apart can my bearers span apart with the h3 140x35 listed above
3: how far apart are my joists using the timbers I have listed above
4: Would tiling and using cement sheet 6 mm tile underlay on top (which I figure would make it even stronger) would this effect the span rules ? If so how and by how much. Thank you for using your brain for me, mine seems to have gone on holidays since I turned 50 and has not returned.
