Hello
This has been an ongoing saga for the past year since I bought this house. At that time, building inspector had said shower had a slight leak to the wall & recommended plumber's investigation. Just had a contractor come out recently for a free shower leak test, which he didn't do as he said there was no need. His moisture meter had 99% on the bathroom floor, however he said if the waterproofing had failed then the floor would be noticeably wet, which it isn't and never is. The linen closet on the other side of the shower is also completely dry. His view was that there is leakage, but that it is all going through the grout in the shower pan & wall tiles as he can see that the grouting has failed. He said that the shower just needs removal and re-grouting ($1,600).
Their company's online profile alludes to their staff's carpentry experience, but no waterproofing or tiling experience, so that threw me a bit. I'm also surprised that seeing as he was there anyway, it wouldn't have hurt to do the flood test, for piece of mind if nothing else, but he was adamant this wasn't needed.
Over the last year I've had about 5 quotes, all saying something different. Two recommended a shower seal to replace the "broken waterproofing" even though this wasn't tested, One said his moisture meter indicated waterproofing failure, but didn't specify why he was so sure it was the waterproofing and not the grout. Others also suggested just resealing the grout.
So there's no definitive test to prove once and for all whether or not the waterproofing is OK? I hope someone there can help and thank you, guys.
