Good morning Workshop Community, this isn’t a project but a reminder, especially for our Perth Gardeners - beginners and experienced. Check and see if your garden soil is really sandy and have a look if it needs to be improved. No doubt it probably will do.
I have just done our No Dig Garden again as we are into a hot summer season and our soil had become very dry and repelling water which then affects growth and health.
Steps
Step 1
Look at this grey , dry lifeless sand.
So bad that the water pools on the top and difficult to absorb down to the root system of plants in the garden.
Step 2
What I like to do regularly and yes it does help to continue this process is to add a soil wetting agent. I like to use the Richgro Ezi Wet Granules, I also use the liquid solution as needed. Granules or liquid are excellent.
Follow the application instructions on the packet.
I added it to the sand so you can see it and then I used my garden hoe to mix it into the sand.
Step 3
I then like to add organic matter to the sand, I always use sheep manure and again use my garden hoe to mix it in well.
Step 4
I always add Rock Minerals as the sandy soil is depleted of nutrients.
Step 5
I always use Triple C to mulch as it is a good moisture retainer but also it breaks down into a beautiful feeding compost. The earthworms and soil microbes will benefit from this.
Step 6
When I add mulch I always make a well around the plants and also make sure it’s not touching the plants trunk. It is a good thick layer. This helps when watering to keep it moist in summer.
i hope this helps you if you have sandy soil in your garden. I will then continue layering and topping it up with sheep manure and triple C , no digging at all, just layering. Happy Gardening 🧑🌾 🌿🪴
