The title was probably not the best way to describe the problem, but I will expand the problem here.
When I connect my washing machine to the spigot on the P trap the water in the drain hose backs up because it appears that the spigot is too small for the volume/pressure of water coming from the washing machine which causes the washing machine to stop its cycle. When I place the drain hose directly into the laundry trough the washing machine drains ok and the washing continues its cycle until completion.
Having the drain hose directly into the laundry trough apparently is not compliant.
Is there a solution?
Thanking you,
Fletch582
