I'm planning to install some top and side brush seals I purchased for my garage door.
Being reletively new to DIY - I wanted to double check a few things:
1. I assume I need masonry bits to install into the garage wall material (photo of garage wall/material below)?
2. I have a Ryobi hammer drill - should I be starting on any specific settings to drill the holes required?
3. Do I need a stud finder to check for wires/pipes within the garage walls before I drill. The screws that came with the brush seals are approx. 25mm in length so assume it's unlikely to be an issue but thought I'd double check.
If there's anything else I should be mindful of before I start I'd appreciate the advice - thanks!
Garage Door
Screws that came with garage seals
Garage Wall Material
