I’m planning to wall‑mount a 4cabling server rack in my garage, and once it’s populated it’ll be around 70kg. The wall is an internal plasterboard stud wall; the exterior of the house is brick veneer. The rack has a rear hinge, though I don’t expect to swing it open often.
Questions:
- Can I wall‑mounted for this weight?
- Planning to mount a structural plywood backing board across 2-3 studs, then mount the server rack to that. What fixings into timber studs are best (coach screws/bolts, washer types, plywood backing board)?
- And how thick should the structural plywood be (12mm, 15mm, 17mm, 19mm)?
- Are there Australian standards or best practices I should follow for mounting heavy equipment to studs?
I’m moving in next week, so I’ll confirm stud spacing soon. Thanks for any guidance or examples from similar installs!
P.S.: I've attached an image of what I'd imagine the installation will be like. Disclaimer: the image is AI-generated using an existing image of our garage, with the server rack inserted into the image.
