I've got a double brick home and have built a stud wall in the dining room to create another bedroom. However, now at the point where I'm a bit stuck.
The gap between the painted solid wall and the gyprock needs to be filled (per picture) and I'm not confident I can just use the Gyprock multi purpose compound. There are also the internal corners (not pictured) that need to be filled (one side of the corner being the solid wall, and the other side being the plasterboard).
1. Can I simply use the gyprock multi-purpose joint compound or do I need to follow another process (or use another product first - someone mentioned Bondcrete but I'm not sure how that works)?
2. Should I be sanding off the paint on the solid wall first or at all?
