Hi
I have some lead flashing on the roof embedded around the base our chimney. Water run off flows down onto a newly constructed colorbond roof. According to BlueScope, this can lead to an increased rate of corrosion. To avoid this they recommend painting existing lead flashings with a good exterior paint system.
Has anyone had any experience with this or have any recommendations for the best type of paint system to use for lead?
Some recommend using a metal primer while another YouTube video swears by a single coat of exterior oil based gloss with no primer.
I should note this is only a temporary fix for a few months as the chimney will eventually be removed. But I thought it worthy of discussion since others may be in the same situation.
Of course when working with lead appropriate PPE and precautions should be taken.
Thanks
