I have some foam core that I would like to attach to the ceiling as a sort of cheap pelmet for heat efficiency and to cover up the curtain brackets, like here https://www.lukearthurwells.com/blog/easy-curtain-pelmet-diy
Could I glue the foam core to the ceiling-if so what glue should I use?
would I need to get some kind of wood trim to reinforce?
I have the ikea betydlig curtain brackets attached to the ceiling and there is room to screw a piece of wood or foamcore to the bracket that I could then glue to the pelmet.
Would this be possible to do with foam core? If not what material should I use?
thank you!
